Hey guys I just did a dyno tune and drove the car and everything was fine. I trailered the car home and pulled it into my garage. I replaced my power steering slave cylinder and then went to take it on its maiden voyage around the neighborhood when its just stumbled and failed to idle or have any kind of throttle response. So I took a KOEO reading and got code 66 MAF sensor voltage low. I cleaned it with MAF sensor cleaner and returned everything back to normal and pulled the negative cable off my battery to reset the ECU. I went to start it again and it did the same thing...
So I metered the power, ground, return and signal wires and they were all good (voltage was good on power, ground was good on continuity to ground and all wires metered good continuity to the 60 pin connector.) The only thing I couldn't check was the voltage with the engine running, because it wont idle.
I replaced the spark plugs and wires as well and cleaned the O2 sensors, but still get the code. I have a PMAS sensor and its only seen maybe 2 hours of use with a new air filter. Maybe the sensor is bad? Or could it be something else? I've taken apart my entire air intake from the throttle body down to the air intake and reassembled and made sure everything was tightened down good.
I wrote PMAS and explained the situation so hopefully they'll exchange it for a replacement.
Another question is is that SCT makes a sensor BA-5000, with my SCT performance chip thats tuned for 30# injectors and a 30# MAF sensor would this be ok? Because I think with these electronic injectors (not a C&L which uses a tube) that you dont need the MAF sensor pre-tuned until 36#. Correct me if I'm wrong.
If I do need a new sensor, not housing, which would be a good, quick, cheap, replacement? ANy info would be good. Thanks forum guys!
