Jim, I used 3M Plastic Cleaner, Part number 39017 and 3M Plastic Polish, part number 39010.
I found a procedure for polishing tail light lenses and it worked really well on mine. It also included using some 2000 grit wet or dry sandpaper but I omitted that step for the clock lens because it wasn't too bad. I suspect that I got the link from this board but I don't remember. The URL is
http://fiero.freeyellow.com/Tail Light polishing.htm
Here is a copy of the procedure:
Lens and Tail light Polishing: Materials and Procedure
It's 2001 and tail lights, dash and gauge cluster lenses are discontinued and not available from GM.
I make no guarantees or endorsements of any type for results or for any product.
I have used these products following advice of people that have been doing professional body work and restorations for many years.
I have done this many times with excellent results. It is the same procedure used to restore the rear plastic 'glass' found on convertible tops.
If you doubt these instructions or yourself, practice on an obscure area or old broken piece of lens or tail light.
Before attempting this procedure read and understand all of this. With that said . . .
If you have scratched (nasty or otherwise) or stained dash lenses or tail lights, repair is not that difficult. You will need:
3M Plastic Cleaner, part number 39017,
3M Plastic Polish, part number 39010 (each ~$6.50 / 8 oz. bottle),
one sheet of 2000 grit Wet-Or-Dry sandpaper (~.60 per sheet),
about 8 - 100% cotton rags (nylon, elastic, polyester, wool or any mix will work against your purpose),
#10 torx tool,
an old towel,
your favorite lens cleaner,
a spray bottle filled with water,
a light touch,
and patience.
I obtained my 3M supplies from Gwinnett Auto Parts - @ 405 Killian Hill Rd. & Hwy 29, Lilburn GA (770)-921-5681
Note: Outside temperature was about 80 degrees F when I did my work.
You do not need to remove the main dash or gauge cluster lenses.
Remove the lens covers (trim) using the torx tool.
First, using your favorite cleaner, clean the lenses.
Using a small amount of the Plastic Cleaner on your 100% cotton rag, lightly rub in small circles and cover the entire lens.
Let it dry and using a different 100% cotton rag and same motion, lightly rub off the residue.
Repeat this as needed. Two to three applications should work best.
If you have a scratch that won't come out, you only need to get the lens to a point where the polish will work.
DO NOT TRY TO ENTIRELY REMOVE THE SCRATCH !
Spread your towel under the lens, spray a small piece of the sandpaper AND the area of damaged lens with water.
In a circle, VERY LIGHTLY rub LIGHTLY!, and while rubbing lightly, continue to spray the area with water.
Now it really looks like you've ruined it ! Be patient.
Apply the Cleaner again, lightly.
Lightly apply the Polish using fresh 100% cotton rags and follow the same steps outlined earlier for the Cleaner.
Repeat as needed.
If you have used a light touch, and been patient, you should now be amazed at the results.
Replace your trim pieces, and admire your work. You've spent about $14.50 (the other stuff is usually lying around the house),
and about 1.5 hours of elbow grease (FREE !).
The same procedure will work on your tail lights.
Unless your tail lights have interior moisture from condensation, you won't need to remove and disassemble them.
If you do, to reassemble them, you will need stuff body shop guys call 'dum-dum' (rope putty) in addition to the above items.
If you try to reuse the old putty, it will not seal properly. 3M makes this too ($10 for 20 yards).
FAQ'S: "Why don't I have to remove everything?"
Answer: "How have you been touching the backside of the lenses?". Disassembly of the dash and tail lights is another story.
I wish you the best of results.
This site supported by Donald Hendrix
Copyright © 2001 (Georgia Fiero Club). All rights reserved.
Last Updated: Monday August 20, 2001
