OK I have installed the new SS hard lines and the 4 wheel disc Cobra brake swap from Mustang Steve but I have run into a snag. :wall:
I bought and installed a Modern Driveline hydraulic clutch kit and now I cannot install my MBM (67 Mustang/Cougar) brake booster and universal disc/disc master cylinder because the booster is just a little too wide so it will not fit because of the clutch master cylinder now mounted on the firewall.
So now I have re-installed my original Bendix booster as the overall diameter is just that little bit smaller that it will mount perfectly next to the clutch master but now I cannot use my universal brake master cylinder because it wont fit between the booster and shock tower.
I need to now find a disc/disc master cylinder that is shorter to fit like the original 67 master was.
Anyone run into this or has installed the Cobra Swap 4 wheel disc kit as I need an idea for a replacement master cylinder???
Thanks for whatever help you can give.
