Hey all. I found some door panels from a paseo that the bottom half match up to my door panels almost perfectly. The only problem is the lining up of the door handle and the window crank. I have already been able to move the door handle without any problems but can't figure a solution for the window crank. Is it possible to move it approx 2-3 inches up and it still roll the window all the way up and down? I had thought about going the electric window route but discovered it was too rich for my wallet, so I have to find an alternative route if there is one.
Thanx
Chuck
Wrecking yard for electric out of car with similar size glass. A friend of mine used late 80's Tbird system for 52 Ford crewcab ( made from 2 52's. He used all wiring and controls from Tbird. He had to fabricate brackets to mount in door but cost was under $100. We have a yard that charges to get in and you have to pull parts with oun tools but cost is less than half of other yards.
