1 - 10 of 10 Posts
Schwing!!!!
You lifted that by the carberator mounting bolts? How high of a lift did you use? How did you get the engine to tilt? Man just those pictures scare me. Looks awesome though. What engine is that?
Weehoo! Good looking one too!
Yup.. Was a little scary.. I just used a standard cherry picker. The engine tilted just about perfect by using the front hook on the lift plate. thats all I used. No leveler at all.
I also jacked up the rear about a foot for better clearance underneath. Had to cut off about a half inch of the A-arm bolts so the headers would clear. Its a warmed over 390.
Good Job. Hard to believe those little bolts held all that! You didn't have any room to spare either!
sweet ! :smoke:
I've been a little leary about using the carb bolts on an aluminum intake myself - I bought one of those plates and never used it!
Old trick also is a skate board , place it under trans tail housing and it will roll right back with the help of some one . no manual lifting under the car .
NICE! Tight fit for sure, I think I would have got the engine almost all the way down, and then tried to bolt up the headers, rather than all at once. Congrats on getting it in!
1 - 10 of 10 Posts
