Before installing the front and rear case I installed the bellows. I would recommend not using cheap crimp pliers. I would recommend using a pair of Oeticker HIP 2000/ 387 band crimp pliers.
They are less than $20.00, made very well and the can crimp from the side or the top.
The front and rear case was installed, aligned and then pressed together per the shop manual that you can download for free here MyMopar - Mopar Forums & Informatio- Service Manu 1967 Dodge Dart + Coronet and Charger service manual on pages 5-22 thru 5-28.
The egg has put together,banded, vacuum checked, valve operating rod adjusted per
and reunited with the master cylinder
This project is done!
