I have a 67 which was originally a 4 wheel manual drum brake car. I am in process of a modification to a coyote swap with TCI suspension with rack and pinion steering and 4 wheel power disc brakes. I need to relocate the master cylinder to clear the engine. At minimum, I need to move it a couple of inches towards the dirver's side fender. I currently have both the manual brake pedal assembly and an assembly from a power brake car. The assemblies have different fulcrum locations and therefore different amounts of leverage and pedal travel. I'm thinking I will use a remote mounted electric brake booster.
My questions:
1. Which pedal assembly should I use?
2. Would it be okay to replace the brake pedal pin which the master cylinder rod connects to with one that is 2 inches longer, or would the increased torsion create a problem?
3 Does anyone know of a tandem master cylinder which is less than 6 inches long so it will fit between the firewall and engine. or of another solution which would allow me to use a stock pedal assembly.
My questions:
