1 - 8 of 8 Posts
I have a '67 with a 289 and factory power steering. My power cylinder just decided to rip itself out of the frame destroying the bracket and cylinder, and widening the holes in the frame. I need to get the car fixed as soon as possible, so I'm trying to figure out if there is a part I can buy to replace the control valve and use manual steering, or if i can just remove the power cylinder and plug the control valve lines. So for the quick list of questions:
How do I convert factory power steering to factory manual steering?
Can I disconnect the pump and power cylinder and use the control valve to move the wheels?
-Will this destroy the control valve?
Will Mustang parts work?
For a quick fix, you can just clean up whatever pulled apart to make sure it won't bind with anything and remove the belt and run it. I ran mine for years like that until I fixed everything. I had blown a pressure hose back then so had no fluid left in the system.....
That looks nice. Would you happen to know the magic word that gets MU to send it overnight? I couldn't get anywhere with the salesman.
I think ill try that until my part gets here. Thanks.
I used the manual steering adapter that replaces the control valve and it works great! the steering is a little harder than factory manual but its no big deal.
Just got the part overnighted, Ill run on the control valve until it gets here. Thanks for the help.
Do you know what size the fittings are in the control valve so I can plug them?
1 - 8 of 8 Posts
