1 - 8 of 8 Posts
If you can't find a used one, you can get a new one from National Parts Depot, $164.95 , page 94 in new book.
You do know if you go with the actual manual steering drag link, you also have to change to a manual pitman arm, right?
What most people do is buy a conversion piece which replaces the control valve:
http://www.mustangsunlimited.com/itemdy00.asp?T1=MU3304A+01
Using this you keep the PS drag link and pitman arm.
Timon is converting his 1970 Cougar from factory power steering, to the Borgeson integral steering. He knows about the manual steer idler and pitman arms.
Would a 69 work? I have one of those. Any critcal measurements for me to take to make sure you can use it?
Kevin
Different tie rod end hole size Kevin.
Hallo,
sry I didnt reply quickly... university needs quite a lot of attention at the moment.
I want to change my Powersteering linkage completly to manual steering linkage because I dont think our TÜV (people who check the safety of your car and give the permission to drive it) wont like the conversion centerlink.
But thanks a lot for your help, I have found someone here in Germany who had the manual draglink, tie rods, idler and pitman arm left from his restauration off his '70 Mustang. So this thread is solved :)
The conversion parts have already been ordered from summit. Really looking forward to the new feel. I will give you some feedback on it as soons as I am on the road again with my cat.
Thanks a lot
Timon
1 - 8 of 8 Posts
