Ok, do you have to remove the old bushing to get the correct measurement for replacing? The catalogs show 2 different sizes.
one is 1 7/16" and the other says 1 9/16". I assume that you have to, being only an eighth of an inch difference. Thanks. Scott
Buy a brand new lower arm by MOOG. part # 8123. Should only cost $45 w/ new bushing, ball joint and arm. Worth every penny!
Does it look like the original arm? Where do you get them? Local parts stores? Scott
Discussion Starter · #4 ·
was just on MU and the Moog was $60 each. by the way, do you have to remove the whole arm to change the bushings?
Bushings alone are $10 ea.
