Hiya gang!
On to the next issue..
I installed an 11" centerforce clutch in my cougar with a 351W and a 4-speed top loader. The problem I have is that the clutch isnt engaging until the pedal is all the way at the bottom of its range of motion (to the floor). I've backed the lower adjusting rod about all the way out to try to lengthen the rod as much as possible, and its only hanging on to the block by a couple of threads. I need another couple of inches of rod length or pedal motion to get the clutch to actuate more fully during the pedal's depression instead of just beginning to engage at the end of the clutch pedal's range of motion. Currently, the car is prone to gear grind, particularly going into reverse because I dont think I'm getting enough push on the clutch for it to fully engage. I can try to find/make a longer adjusting rod, but I'm wondering if perhaps I'm missing something a bit more obvious along the way. Any thoughts?
