Hello. BGrants son Tim here. I was wiring up my dads new radio and ancidently grounded the yellow wire(which is supposed to have power all the time) and it sparked out and now has no power. :argue: Looked at the fuses, none were blown. Now i cant find out why the dash lights aren't going on and there is still no power to the radio:confused:. Any help or ideas on the subject would be appreciated.
Thanks in advance. - Tim
used a tester to check the fuses. Sometimes you cannot see that they are blown. With a 12volt probe test light check both sides of the fuse. And make sure the fuse is seated good between the clips.
Thank you, the problem was an additional fuse that was blown in the line - Tim
