1 - 20 of 285 Posts
Hey all,
I was going through some of my old printouts and came across this old posting listing different member's wheel and tire size combos, including backspacing.
Since there have been so many wheel/tire postings recently, I thought I would revive it. Please add/modify your combo in the list if you are so inclined.
Last Posted: 15 March 04 - Now updated 13 Feb. 2005
Wheel Tire Bkspng Year Location Poster Notes
FRONTS:
14x6 235/60/R14 4 70 Front Jim K
14x7 215/70R14 4.25 69 Front Bruce H. Tire rubs A-frame when cornering
14x7 235/60/R14 _ 67 Front John Ludorf
15x7 215/60R15 3.5 69 Front Logan
15x7 215/60R15 4.25 69 Front Rick
15x7 215/65R15 __ 69 Front Steve Polansky
15x7 215/65R15 4 67 Front Neil Rubs fenders in bumpy corners
15x7 225/60R15 3.75 69 Front Andy S
15x7 225/60R15 4.125 68 Front Leon Minilite Replica
15x7 225/60R15 4 67 Front Neil Rubs center of fenders on heavy bumps
15x7 235/60R15 4 69 Front Bill Q
15x7 235/60R15 3.75 69 Front Paul D Front corner wheel lip mod necessary
15x7 235/60R15 4 68 Front Leon Only rub on tight turns that have a drop off
15x7 245/60R15 4 70 Front Bill Q
15x8 195/60R15 4.5 70 Front WVcat
15x8 215/60R15 4.5 68 Front Kelly S. Front rubs on tight corners
15x8 225/60R15 4 68 Front Les C
15x8 225/60R15 4.25 67 Front Paul L
15x8 235/60R15 4.25 69 Front Mike (Old Wood)
15x_ 225/50R15 __ __ Front Scott
15x_ 225/60R15 3.7 68 Front Greg Front Rubs
15x_ 225/60R15 4.75 68 Front Greg Front Rubs
15x_ 225/50/R15 _ 68 Front John Ludorf Shelby GT500 Wheels w/ 1/4" spacer
16x8 205/55R16 4.5 68 Front Eric O. Global West control arms, slight overage ground off
16x8 205/55R16 4.5 68 Rear Eric O. Rolled fender lip required
16x8 225/55/R16 70 Front Steve
16x8 225/50R16 4.5 70 Front Jeff J.
16x8 225/50R16 4.5 69 Front Bill Q Front Arms lowered 1”
16x8 225/50ZR16 4.5 69 Front 1" Lower 620 Springs Andrew (atomicbob)
16x8 245/50ZR16 4.5 70 Front Wiley L.
17x7 235/45/17 4.5 68 Front Mark (Local Hero)
17x8 235/45ZR17 4.75 69 Front Leon
REARS
14x7 245/60R14 4 70 Rear Jim K
14x7 245/60R14 4.5 69 Rear Bruce H
15x7 225/60R15 4.125 68 Rear Leon Minilite Replica
15x7 235/60R15 4.25 69 Rear Rick
15x7 235/60R15 4 69 Rear Bill Q
15x7 245/60R15 4 70 Rear Bill Q
15x7 255/60R15 3.75 69 Rear Andy S
15x8 245/60R15 4.5 68 Rear Kelly S.
15x8 255/60R15 4.25 Rear Paul L
15x8 275/60R15 4 68 Rear Les C
15x8 275/60R15 4.25 69 Rear Mike (Old Wood)
15x8 275/60R15 4.5 70 Rear WVcat
15x8 295/50R15 4.5 69 Rear Logan
15x8 295/50R15 4 68 Rear Les C Rubs Leaf springs
15x8.5 245/60R15 3.75 69 Rear Paul D Rolled fender lip required
15x8.5 255/60R15 3.5 69 Rear Joe S. Rubs Wheel Lip
16x8 225/55/R16 70 Rear Steve
16x8 225/50R16 4.5 69 Rear Bill Q
16x8 245/50ZR16 4.5 70 Rear Wiley L.
16x8 255/60ZR16 4.5 69 Rear 1" Lower Mid-Eye Springs Andrew (atomicbob)
16x9.5 275/50R16 5 70 Rear Jeff J. Shaved wheel lip
17x8 235/45ZR17 4.75 69 Rear Leon
17x11 285/40/17 5.75 68 Rear Mark (Local Hero)
__________________
I have an update to the list: My rears are now 18X10 with 4.75 backspace and a 295/45-18 tire. This is accomplished by use of air-ride suspension.
Thanks.
Perhaps we should mention the small fender flares that Mark has on the rear of his car as well. If a 295 would fit without mods under a 68, I'd have them already. :sun:
Once I have the final backspacing figured out on my 18" wheels, I will contribute the info.
cheers
Ed N.
cheers
Ed N.
Right you are Ed! I neglected to mention those. They've been there so long that I forget that they are even there. Although, I think I could get the 295s to fit without the flares if I was able to get different backspacing on the wheels. That and the inner wheelwell work we did could be enough to make it work. But, I'll never be able to find out on this car since the flares are basically permanent.
I'd have to disagree with you there Mark. Unless you got into doing mini-tubs on the car, that much tire isn't going to go on a 67 - 68, assuming stock ride height or lower.
Last fall, before my Coug went away for the season, we had it up on the hoist here at the dealership doing a few small things. I had a rear wheel off the car, so out of curiosity, I was trying a few of the late model Mustang OE and aftermarket wheels we have on display here. One of them was a Torq-Thrust II, 17 x 9.5", with 6.25" backspacing for a 94 - 04 Mustang application (no tire mounted on it). A 9.5" wheel is about 10.5" (approx. 270 mm) edge to edge. It was almost against the leaf spring on the inside, and very close to the fender lip on the outside. So IMO a 295 section width tire would not fit in that same space, if the car actually had to roll and drive. LOL My guesstimate is that a 265 or maybe a 275 width tire would be the maximum, depending on the ride height of course. If the car is raised enough that the wheel opening arch is higher than the tire, you can get away with more width obviously.
cheers
Ed N.
Right Ed. I understand what you're saying and I agree with you. 295s aren't going to fit in a stock wheelwell. But mine aren't stock. We did some minor massaging way back in the 80's to fit the L60-15s that were so popular then. It's not really mini-tubbed but kind of. So in MY case I think I could make it work without the flares.
Just trying to clarify.
That's cool. Where did you alter, was it the inner wheelwell above the frame rail and leaf spring? Just curious ... :)
cheers
Ed N.
cheers
Ed N.
Yes. We heated up the inner fender lip just above the frame rail and bent it inward a little to make more clearance. But we also trimmed the bracket that holds the bumpstop. The bracket is now only the size of the rubber bumper. With a stock 69 9" rear, my last set of 17X11 rims with 5.75 backspacing fit fine will room still left on the inside. I was shopping for a pair of 305/45/17 tires for those rims. But then found that they were discontinued. So I had to go with the 18s.
As the originator of the wheel/tire list, please send additions to me so I can add them to the master file. Any modifications are important so I can keep wheel/tire combos that fit w/o problems separate from those that require mods. I definitely don't want someone to spend $1000+ on tires and wheels based on this list to then find out it only works with some specific aftermarket part or shaved wheel wells. I'll compare the list above with what I have and probably hit up posters of new entries for additional info to make sure all the pertinent info is captured and then post the updated list.
Thanks,
Discussion Starter · #11 ·
Well, I'm not sure about how well the underlines work but the site doesn't allow tabs or multiple spacing to line things up so here is the updated info. Thanks for the updates.
Latest data: 17 FEB 05
Wheel___Tire___Bkspng_Year___Loc__Poster_____Notes</B>
14x6___235/60R14__4____70__Front__Jim K
14x7___235/60R14__ _____67__Front__John Ludorf
15x7___215/60R15__3.5___69__Front__Logan
15x7___215/60R15__4.25__69__Front__Rick
15x7___215/65R15__ _____69__Front__Steve Polansky
15x7___225/60R15__3.75__69__Front__Andy S
15x7___225/60R15__4.125_68__Front__Leon_____Minilite Replica
15x____225/50R15__ ____ ___Front__Scott
15x7___235/60R15__4_____69__Front__Bill Q
15x7___245/60R15__4_____70__Front__Bill Q
15x8___195/60R15__4.5___70__Front__WVcat
15x8___225/60R15__4_____68__Front__Les C
15x8___225/60R15__4.25__67__Front__Paul L
15x8___235/60R15__4.25__69__Front__Mike (Old Wood)
16x8___225/55/R16__ ____70__Front__Steve
16x8___225/50R16__4.5___70__Front__Jeff J.
16x8___225/50ZR16_4.5___69__Front__Andrew (atomicbob)_____Lowered 620 springs
16x8___245/50ZR16_4.5___70__Front__Wiley L.
17x7___235/45R17__4.5___68__Front__Mark (localhero)
17x8___235/45R17__4.5___68__Front__George N.
17x8___235/45ZR17_4.75__69__Front__Leon
17x8___245/45ZR17_4.5___69__Front__John Lewis
14x7___245/60R14__4_____70__Rear___Jim K
14x7___245/60R14__4.5___69__Rear___Bruce H
15x7___225/60R15__4.125_68__Rear___Leon_____Minilite Replica
15x7___235/60R15__4.25__69__Rear___Rick
15x7___235/60R15__4_____69__Rear___Bill Q
15x7___245/60R15__4_____70__Rear___Bill Q
15x7___255/60R15__3.75__69__Rear___Andy S
15x7___275/60R15__4_____69__Rear___Jay W
15x8___245/60R15__4.5___68__Rear___Kelly S.
15x8___255/60R15__4.25__ ___Rear___Paul L
15x8___255/60R15__5_____69__Rear___n2fordmuscle
15x8___275/60R15__4_____68__Rear___Les C
15x8___275/60R15__4.25___69__Rear___Mike (Old Wood)
15x8___275/60R15__4.5____70__Rear___WVcat
15x8___295/50R15__4.5____69__Rear___Logan
16x8___255/60ZR16_4.5____69__Rear___Andrew(atomicbob)_____1" lowered Mid-eye springs
16x8___225/55/R16_ _____70__Rear___Steve
16x8___225/50R16__4.5___69__Rear___Bill Q
16x8___245/50ZR16_4.5___70__Rear___Wiley L.
17x8___235/45R17__4.5___68__Rear___George N.
17x8___235/45ZR17_4.75__69__Rear___Leon
17x10__275/40ZR17_5_____69__Rear___John Lewis<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com /><o:p></o:p>[/font]
<font face=" /><o:p></o:p></FONT>
<FONT face=Arial>Some Issues</FONT>
<FONT face=Arial>15x____225/50/R15__ ____68__Front__John Ludorf_______Shelby GT500 Wheels w/ 1/4" spacer</FONT>
[font=Arial]15x7___235/60R15__3.75__69__Front__Paul D___________Front corner wheel lip mod necessary[/font]
[font=Arial]15x7___235/60R15__4_____68__Front__Leon____________Only rub on tight turns that have a drop off[/font]
[font=Arial]15x8___215/60R15__4.5___68__Front__Kelly S.__________Front rubs on tight corners[/font]
[font=Arial]16x8___205/55R16__4.5___68__Front__Eric O.__________Global West control arms, slight overage ground off[/font]
[font=Arial]16x8___225/50R16__4.5___69__Front__Bill Q____________Front Arms lowered 1”[/font]
[font=Arial]17x7___235/45R17__4.5___68__Front__Mark____________Front has been lowered[/font]
[font=Arial]16x8___205/55R16__4.5___68__Rear___Eric O.__________Rolled fender lip required[/font]
[font=Arial]15x8.5__245/60R15__3.75__69__Rear___Paul D__________Rolled fender lip required[/font]
[font=Arial]16x9.5__275/50R16__5_____70__Rear___Jeff J.__________Shaved wheel lip[/font]
[font=Arial]17x11__285/40R17___5.75__68__Rear___Mark (localhero)__Minitub w/Air bags[/font]
[font=Arial]18x10__295/45R18___4.75__68__Rear___Mark (localhero)__Minitub w/Air bags<o:p></o:p>[/font]
[font=Arial]Known Problems[/font]
[font=Arial]14x7___215/70R14___4.25__69__Front__Bruce H.________Tire rubs A-frame when cornering[/font]
[font=Arial]15x7___215/65R15___4_____67__Front__Neil____________Rubs fenders in bumpy corners[/font]
[font=Arial]15x7___225/60R15___4_____67__Front__Neil____________Rubs center of fenders on heavy bumps[/font]
[font=Arial]15x____225/60R15___3.7___68__Front__Greg____________Front Rubs[/font]
[font=Arial]15x____225/60R15___4.75__68__Front__Greg____________Front Rubs[/font]
[font=Arial]15x8___295/50R15___4_____68__Rear___Les C__________Rubs Leaf springs[/font]
[font=Arial]15x8.5__255/60R15___3.5___69__Rear___Joe S._________Rubs Wheel Lip[/font][/font]
Bruce,
Put your data into a spreadsheet PM me and I'll mail it to you.
<TABLE borderColor=#cc0605 cellSpacing=2 cellPadding=2 width=667 border=1><TBODY><TR><TD width="7%" height=20>
Wheel​
</TD><TD width="12%" height=20>
Tire​
</TD><TD width="8%" height=20>
Bkspng​
</TD><TD width="3%" height=20>
Yr​
</TD><TD width="4%" height=20>
Loc​
</TD><TD width="19%" height=20>
Poster​
</TD><TD width="47%" height=20>
Notes​
</TD></TR><TR><TD width="7%" height=17>
14x6​
</TD><TD width="12%" height=17>
235/60R14​
</TD><TD width="8%" height=17>
4.00​
</TD><TD width="3%" height=17>
70​
</TD><TD width="4%" height=17>
Frt​
</TD><TD width="19%" height=17>
Jim K​
</TD><TD width="47%" height=17>
14x7​
235/60R14​
67​
Frt​
John Ludorf​
14x7​
245/60R14​
4.00​
70​
Rr​
Jim K​
14x7​
245/60R14​
4.50​
69​
Rr​
Bruce H​
Minilite Replica​
15x​
225/50R15​
Frt​
Scott​
15x7​
215/60R15​
3.50​
69​
Frt​
Logan​
15x7​
215/60R15​
4.25​
69​
Frt​
Rick​
15x7​
215/65R15​
69​
Frt​
Steve Polansky​
15x7​
225/60R15​
3.75​
69​
Frt​
Andy S​
15x7​
225/60R15​
4.13​
68​
Frt​
Leon​
Minilite Replica​
</TD></TR></TBODY></TABLE>
Dumped the data into Excel. Converted text to columns. Split text at the "_" characters.
For guys like me that are too picky, it would be interesting to get (if possible), the brand and model of the tires used as well as the sizes, for the list. The reason being, as you may know, actual tire dimensions can vary quite a bit between different models of tires. For my 5.0 Mustang race car, I remember having 3 different brands of 245-50-16 track compound tires sitting in my garage at the same time. From 5 feet away, you could easily see the variations in the width and height of the tires.
Could be important info for a maxxed out tire fitment. One brand in a certain size may fit, but another one might not. Knowing the brand and model would allow us to compare the dimensions of the tire we are planning to use, with the dimensions of a kwown to fit tire from the manufacturer's website (if it's a current production tire).
Just a thought ... :)
cheers
Ed N.
ddelcore said:
[/font]
Bruce,
[/font]
Actually, I keep it in Excel now but with a cut/paste the info ends up too large (exceeds 10000 char). Can't upload it either, site only allows photos, not .xls files.
cheers
Ed N.
True, I've run into that also. Too bad I didn't think of it a couple of years ago when I started this file. :(
But, if anyone here has recently added something or has something that matches something listed above, send me the tire brand & model line and I'll start filling it in from here on.
another tire size question < sorry>
on my 70 coug xr7 i have the original sports wheels still in great shape with yes you guess it the old dunlop qualifer , te car has 57 k miles> if i would to keep those wheels then replace the tires something more up to date what would be the right size
but if i would buy a set of 15 magnum what would be the right size as well
hope some one will answer that
take care terry :cyclops:
More Info
Bruce, my fronts, 235/45/17 are BFG G-Force KDWS. The rears on the 17X11s are 285/40/17 BFG G-Force KDWS. The rears on the 18X10s are 295/45/18 BFG Comp TA.
New "Paws" for the Cat
Hi all,
I took the easy way out for my new '69 convertible with Winston Winner G/T's on 14x7 SS Cragers (I'll add a pic with the wheels this evening).
Front - 205/70/14 Back - 235/60/14 ...so much for rotating tires.:burnout:
$940 total with alignment at Big O.
Chuck
1 - 20 of 285 Posts
