I hope this turns out. I took some pics of AlphaCat's rear end setup and colored it to make it clearer (for ease of acuity)
:ylsup:
Discussion Starter · #5 ·
Rick,
Mine are definately wedges. They taper from 1/4" thick at the front to 1/2" thick at the back. If you've been following the other thread on these, you'll see that they are a 3 degree wedge angle.
Looks good cj- I have everything bolted together without the wedges, but I have them modified them to go back in. All I have to do now is grind the slots in the sides of the wedges for u-bolt clearence, cause the '69 stang shock plates bolt pattern is closer to the leaves that the original cougar design.
Discussion Starter · #7 ·
Axle locators?
Not really axle locators, Rick. The axle is located to the spring by the spring binder bolt. The binder bolt goes through a hole in the wedge and still is long enough to fit into the center hole in the axle mount.
