I coated the short gaskets and the surface they rest on.
Do you have to coat the long gaskets to the heads?
I used gasgacinch.
Not usually, a little around the water openings would not hurt.
The problem with the rubber and cork, is they tend to slip when tightened, and leak in the corners where the manifold sits. Run a bead of your sealer, about 1/4 of inch thick across both front and rear surfaces and throw the others away, be sure to lap some or the sealer up on the manifold gasket at the corners.
