Well, this past week i'd been having troubles with my intake manifold. The first time i put it on, it leaked out the front and back, so i pulled it off and put it on again. So when i added coolant, all looked good until i noticed a leak coming out of one of the stud bolts. I asked around and everyone i've talked to said that isn't normal. I know before i took it off there was water in the stud bolt holes cause the old bolts were starting to get coroded. THe only thing i noticed that's warped on my manifold is the hole for the leaking stud bolt. The surface that meets the washer is cut away, looks like a hack job, but it doesn't sit flat to the washer. So basically i'm trying to figure out what's going on with my engine, and any ideas are appreciated.
