1 - 2 of 2 Posts
Withe the pink wire in place, what is the voltage at the coil with the key in the “run” position? Thx
roughly 7 volts on the ones i have tested... but varies with your base voltage for example... if you have only 12 volts before the resistor wire .. output will only be roughly 6 volt if you have 14 volts before it output will be closer to 7 .... these are just random numbers.. best to use a digital multi meter and test yours if you want to be exact.
1 - 2 of 2 Posts
