Hi all,
question i think its the same but not sure the door locks and the ignition cylinder are all used by the ignition key correct? If so i swapped a column w/ a fellow cougar person and may as well give him the door locks if its true. Because the column i got when the key is out it can spin freely around w/o any key inside so i may as well get a whole new set.I had a tilt in my eliminator but did not like it cause im so use to my vert having no tilt so i like the feel better.
thanks
pat
thanks
pat
