I have a couple of pedal hangars from 67/8 cars, both for an automatic,, I.E. wide pedal. Is there a way to confirm one is for power brakes? There is no pad that says "power brake" on either...
If they are like 69/70 (and I think they are) the PB pedal has the pivot up high in the hanger and MB pedal lower (shares the same pivot as the clutch pedal - if there was one).
67-68 use the Same Support/Hanger where 69 and 70 are different between the 2 years. The extra Width of the 68 Pedal doesn't make a difference for the Support. Power Brake Hanger only has one pressed-In nut at the Fire Wall Flange, Top LH. Manual Trans Hangers will have Beefier Metal Bushings on the Side to support the Clutch Pedal. Auto Trans Hangers will not.
