1 - 2 of 2 Posts
Any help Is appreciated . I am a new owner of a 1967 cougar. On the rear pig I found a factory tag with this info .wcz-vl 9f0 and the second line is. 2.79 8. 930A. I am trying to identify if it's a limited slip and gear ratio.
Easiest way to tell if you have a factory limited slip it the ratio number will have a "L" in it. Yours is a 2.78 8 inch open. If it were a limited slip it would read 2L.79
1 - 2 of 2 Posts
