Anybody upgrade to hydroboost on their 67-68? Im having no luck on searching for a Cougar power brake booster so i thought i would look into hydroboost. Welcome to all responses good and bad
thanks
Rick
thanks
Rick
Hope this helps. I used a modified reproduction Boss 429 booster wedge to tilt the hydroboost up to clear my coyote engine valve cover.Thx for the quick response, got any pics, I’m guessing a tight fit with a 390?
Yes, that helps a lot, especially the use of a wedge kit, thank youHope this helps. I used a modified reproduction Boss 429 booster wedge to tilt the hydroboost up to clear my coyote engine valve cover.
If you decide to go the used route, try to find one with the mounting plate already attached. Most will angle the hydroboost up already. You can easily modify the plate to bolt to your pedal support. It'll save you some money from having to purchase the wedge like I did.Yes, that helps a lot, especially the use of a wedge kit, thank you
