I have decided to replace the entire dash clip assembly in my 67. It's been cut for a stereo and it looks like a previous accident damaged the right side. I am doing a restomod, so not to worried about originality.
What is the best way to remove this section? I see that it is bolted on the bottom (support arms) and at the side as well. It appears that only the top is welded. Is it recommended to drill out the spot welds, cut off the dash piece as close to the welds as possible and grind remainder off...? :wave:
