Thanks for the input guys. Actually, the new motor will be "sporting" a 130 amp alternator so I should be set as far as power goes. I just wondered if anyone had done it. Thanks again!Bruce said:Yes, you can do it. I don't know if the system will have enough juice to run them off the stock alternator though. Try this test. Turn the headlights on, the fan, and the wipers. Have someone put the car in drive and hold the brake. If all the brake lights work, try the turn signals. If everything still works, you might be able to do it. If not, you will need to upgade the alternator before rewiring your marker lights.
