1 - 13 of 13 Posts
I installed an electric fan on my 67 about a year ago.
Normally it works just fine but I've noticed that, when sitting in traffic, the temp gauge will start to climb quite a bit before the fan is turned on by the thermal switch.
I am thinking about installing a switch to turn the fan on manually so the heat doesn't get a head start. Maybe a simple toggle on/ toggle off button or something similar.
The interposing relay doesn't have power when the key is off so I don't have to worry about forgeting to toggle the fan off when the car is parked.
If anyone else has had this situation arise, how did you go about correcting it?
So I take it your fan controller is not adjustable?
The unit I have can be adjusted to activate the fans at various temps.
I did what you're thinking -- put a switch in parallel with the thermal switch. That way I could cool it down at the track as needed.
because our 67 gt is driven by my wife ,i didn't want any outside switches---i bought the spal pwm system to run their dual 11"fan system---i fought the set up with the tech until i did two things:# 1---donot use the spal sensor---use the chrysler sensor they TRIED to copy---# 2 run at least a #4 wire from the neg bat terminal to the "chassis "ground they recomend---with these changes you can keep the car @ thermostat temp with the a/c on @95deg out side
doctordesoto
a adjustable thermostat mounted right to the radiator is the way to go! If you have a good charging system there shouldnt be any probablem with the fan rinning for a little while after its shut off ! restarting it with a cooled of moter is always a good thing!
If you have a sensor in the manifold or somewhere on the engine you can install a sensor that cuts in at a lower temperature - you need to check out the parts book at the local auto store. An adjustable sensor from SPAL or Dakota Digital is a good idea but will cost a lot more than a suitable sensor. I ended up using a sensor from a Triumph Stag
http://www.dakotadigital.com/index....tegory_id=403/home_id=-1/mode=prod/prd641.htm
A lot of problems have popped up with FAN SWITCHES. Lots of bad info floating around, and a RELAY should be a main part of any fan switch system, IMO.
Dale in Indy
When I installed an electric fan in my old F150, I used an underhood thermal switch in conjunction with a three-way switch in the dash: ON-OFF-THERMAL. Was very happy with that set-up. I normally kept it on the thermal setting, but was nice to be able to manually turn it on for hot weather, and turn it off on cold days when a fast warm-up and extra heat were desired.
Dale in Indy
+1
Running a fan (or any hi-amp draw) should be run through a relay with the thermal switch actuating the relay.
1 - 13 of 13 Posts
