On my 67 Cougar , 289 motor, I had a problem the other day big time, car was running , went to shut car off, car continued to run , even with key turned off and removed. So I had to pull coil wire , then motor died , but then it keep trying to start until starter was grinding, pulled the NEG battery terminal, finally everything stopped. So I went and bought a new ignition switch and installed it and also installed new solonoid relay, now with both solonoid relay coil wires not connected (meaning the two small wires that plug onto the solonoid relay disconnected) now I installed battery first the positive terminal, then as soon as I installed the negative terminal on battery the car tried to start all on its own, how is this possible. Could the starter motor itself be grounded , if I put a continuty tester lead on the wire that goes to starter and the other lead to ground ( any metal on car ) I read continuty
