I have a 70 and the Hi horn is out. Will the high horn of a 70 Mustang work? I'm only asking since I'm going to the Pomona Swap Meet in the morning. If not then I'll order from WCCC.
Yes, I am pretty sure a 70 Mustang horn is the same. BTW, have you tried applying power to the horn and then adjusting the screw on the side of the horn? Many times making this adjustment will restore functioning of the horn.
I just did try that. It makes a noise like it wants to blow... No matter which way I turn the screw it only makes that noise... Thought I'd give it a try...
Thanks
Bang it fairly hard against a piece of wood a couple of times and try again. Bet you can get it going.
