1 - 2 of 2 Posts
I found that the anchor 2370 motor mount ($10 at O'Reilly;s)
http://www.oreillyauto.com/site/c/detail/ANR0/2370.oap?ck=Search_2370_-1_1142&keyword=2370
is a rubber isolated mount but has interlocking metal the will not permit the mount to separate. Ever had this happen? I have and it pulls the accelerator tight so you can't get off the gas!! The mount Looks very similar to $175 pair here
: http://www.mustangsunlimited.com/itemdy00.asp?T1=MP10147+01
The anchor mount has large pressed rivets where the above has bolts and nuts. The spread on the frame mount was a little wide but pulled down tight with I torques the through bolts. They show up as 1972 Mustang Q code mounts.
There are two different numbers 2370 and 2371, but the 2371 has a wider bolt pattern to the block. I modified it to work since by elongating both bolt holes a bit. Next time I will use the 2370 for both sides.
BTW I used them on a 351 transplant to a 67. Still had to change the frame mounts to later model.
Hey I'm looking for exactly what I believe you have found. A little unclear of what you're saying here though. I need a pair of the motor mounts for my 67' and I've installed a 351C with the factory mounts for a 289/302/351W/C. They fit but are only rubber and make me very nervous so i'd like to find the urethane mounts with steel overlap deal that keeps them from ever separating if the urethane breaks. I have seen the ones in mustangsunlimited but prefer find something else if applicable. Thanks again.
1 - 2 of 2 Posts
