1 - 2 of 2 Posts
i have an edelbrock carb 600cfm and i need i know which vacuum line goes where from the distributor?the distributor has to dual vacuum lines?when i bought the car there where no lines connected and car ran fine.but i rebulit the engine and want to hook them up.why would someone do this?later on i want to change it.:1zhelp:
the line pointing out from the dist. to the passenger side bottom right side of the carb, and plug the line pointing up on the dist.
The line pointing up goes to the intake vaccuum, and T'd to the valve on the thermostat if you have one, if you dont, just plug it. It is just an emission thing for when you de-excellerate it opens the vavle on the thermostat and does something useless,lol. Not needed so just plug it.
Rick
1 - 2 of 2 Posts
