Ok here is the deal, as you all know i have a 73 XR-7 Triple Ginger Cat, well my string of bad luck has once again caused yet another problem! I drove it last night and all was fine but when i pulled it out of the garage this morning , it had a new NOISE that i was unfamiliar with, after a quick call to a friend it was determined that a Lifter had collapsed or a broken rocker arm, but with my luck it would be a Lifter! Anyway i am not that mechaniclly inclined and nor do i have the money to repair her now or for a while, and it is my only car! So i am thinking of either selling her, trading her, or parting her out to fund a new Cat that runs good.
I will give the run down about her:
351 C 2V FMX 2:75 open rear
NEW Suspension ALL of it
New Rad, ALT, Hoses, Belts, Cap rotor Wires, Plugs(all motorcraft except rotor)
Near perfect Ginger Interior(no cracks in dash pad, drivers seat has 2 small tears, and headliner has small tear, Perfect console, rear set is good)
New tires, brakes, brake line to rear
Chrome is good
weather stripping is good
new fuel pump
only needs minor things which i can get if need be, 1/4 panel on passenger side , steering coloum sleeve(car was broken into and Lock was pulled out of coloum sleeve), carb should be replaced
AND IT APPARENTLY NEEDS A LIFTER!!!
Has great oil pressure and ran fine till this morning
Car is located in Springfield MA
So all please let me know what i should do i trust all of your opinions and judgement so please speak up!!!:1zhelp:
Chrome is good
new fuel pump
