1 - 10 of 10 Posts
Im new to the forum and was hoping someone could help me with the vin # 1F91H592161,
Any info on it would be great. Thanks again:wave:
<table id="Table1" border="1" cellpadding="0" cellspacing="0" width="600"><tbody><tr><td align="right" valign="bottom" width="30%">Model Year </td> <td> 1971</td> </tr> <tr> <td align="right" valign="bottom" width="30%"> Assembly Plant </td> <td> Dearborn, Michigan (F)</td> </tr> <tr> <td align="right" valign="bottom" width="30%"> Body Style </td> <td> Standard, Hardtop 2 dr (91)</td> </tr> <tr> <td align="right" valign="bottom" width="30%"> Engine Model </td> <td> 351-2V Cleveland (H)</td> </tr> <tr> <td align="right" valign="bottom" width="30%"> Sequential Number </td> <td> 92161</td></tr></tbody></table>
If you supply the door tag numbers more info is readily available.
That is a bogus VIN number, they made far fewer 1971 Cougars than 92,000. Please don't turn that into the National Data Base.
ok..got the door panel info.... 65D M
1D 6 X 52....can anyone help with those? Thanks!!!!
65D-2 DR Standard HT, M-Paint code White,1D-Dark Red standard bucket seats, 6-Axle code 3.00:1 ratio, X-Transmission code FMX Automatic & 52-DSO Los Angeles. BTW, welcome to the madness. John
they said it had a vinyl hard top but they replaced it with a regular one, how can i find out what the original vinyl color was? Thanks!!!
The body buck tag normally has that information. Called out as a color on the end of the second line.
Buck tag is located on the radiator core support, can be on either side. Look for a black painted tag beside the headlights behind the grille.
1 - 10 of 10 Posts
