On my '69 XR-7 convertible when I took the fuel line retainer clips off of the bottom of the car (driveline tunnel) there were some type of plastic gromets in the floor pan that retained the clip. The clips pushed into the grommets. I need new ones, anybody have any ideas where I could get them or a reasonable alternative?:confused:
I have new clips, same as oem, with the stainless steel tubing that I bought from right stuff. What I need is the grommets, is that what you are talking about?
No, although AMK sells both the clip and the retainer. I should have been a bit more precise as the retainer and clip are two different things in this case. The retainer is a little butterfly like thing that goes through the clip that expands when you squeeze the "wings" on the other end.
