so i went out to move my dads cougar an tried the wipers and nothing.I dont believe he has ever used them. so what should i do and where is best to start checking to resolve this problem?
Is the motor making any noise? If so, check that the arm hasn't fallen off of it. I had the little e clip thing break on mine once and the wipers stopped.
I'm sure you looked for the obvious - fuse, plug looks ok.....try seeing if the switch works if you have a test light or a meter. See that you have 12 coming in and of course coming out when you switch it. Could be the motor or the switch...
