Before I go ahead and have a custom boot sewn up for my 68 convertible conversion, I thought I'd look into whether or not a stock boot from a 69-73 convertible might be a close enough fit. Any 'vert owners here willing to spend a few minutes with a tape measure? I need the measurements along the red lines in the attached pic. Thanks in advance for all help.
These are the measurements for a "69" 13 3/8, 28, 63 inches.These measurements can vary depending on exactly where you measure from. If you need something closer you will have to specify the exact point of where you require the measurements.
Rats. That's about 1.5 inches too narrow behind the rear seat. The other two dimensions seem to be the same. Thanks for checking, alc.
