I just installed a new switch in my 70 XR7, the vacuum works fine, all of the lights work fine except the headlights. Where do I look next? I have replaced a fuse that looked bad, is there another fuse somewhere other than the fuse box?
Thanks,
RayJ:1zhelp:
Does anyone know where the relay is? I really need to get this fixed so I can get it inspected. Any help would be greatly appreciated.
Thanks,
RayJ
I had a similar problem on my 70 and it turned out to be the dimmer switch in the floor. The contacts were all corroded and after cleaning them up....voila, the headlights came back to life.
This may not be your problem but it's worth checking it out....
Dale
Thanks, I didn't think about the dimmer switch. I'll check it this weekend. I'll let you all know what I find. This group is extremely helpful!
RayJ
