Hey guys,
Hope you are all well. Just had a brake question I was hoping someone here could answer. I bought new brake lines for my 69 vert from Mustangs unlimited (That may be my first problem) Anyways everything seemed to fit, except that my new line running to the rear brakes had like a 3/8 fitting instead of a 1/2 so it only fit the port closest to the back of my distribution block (instead of the front) and the right front line is supposed to fit in the rear port but wont fit either. If it did not matter I was just going to get a flange tool and new fitting to make the right front one fit in the hole closest to the front. I am sure this is confusing as even I am cofused!
Simplified. Does it matter if the lines are reversed leaving the bottom of my brake distribution unit? It is the rear line and the right front reversed. Any help would be great. Thanx, Bish :uhoh:
