So I need to change the heater hoses on my 69 XR7 351 (M Code) with no A/C. The hoses are getting old and cracked and it is definitely time. The problem I'm having is that the hoses disappear into the firewall with no visible hose clamps under the hood. Do I really have to go under the dash to change these hoses? Is this the factory set-up or was this the bright idea of a former owner? Has anyone done this job? Is it easy or am I going to be letting loose with a few choice words halfway through it?
Yes, factory set up. If you remove the dash pad, you should be able to get to the clamps, with a few choice words.
Removing the dash will be easier than going underneath. Thanks.
No offense, but the title of your thread gave me a bit of agita when I first saw it... :buck:
you can take the glove box out and actuall see where they connect to the heater box before you remove the dash.
