SO,
I drained the coolant system. Disconnected the heater hoses. Removed the defrost tubes from the plenum. Disconnected the defrost, heat and temp control cables. Now I'm a little on the stuck side...
Is the heater box attached to the firewall with a couple of nuts? I'm not seeing any. The blower motor got to come out with the heater box as an assembly? The studs and nuts are visible on the firewall for this if it is necessary.
Anything else to disconnect?
Any help would be great....
