I just pulled the valve cover of my right cylinder head to see if I can find out what heads are on. Underneath I found the following numbers which don't help me (novice as I am) much:
Between cylinder 2 and 3 there's a big 0 (zero) and between cylinder 3 and 4 it says 4D28.
Anyone here knows what that means?
Btw, the engine probably is a 289 (casting number of intake C6, autolite 2100 carb, casting # of the block probably C6 (could be C8)).
Thanks,
Matthijs
Thanks,
Matthijs
