HAI GAIZ!!!
I finally got my ass out to the car again to start working on it. The GF got a job recently, so now she works on Sundays so that means car time!
I managed to pull the vacuum lines out of the engine bay, and I got all of the headlight harnesses disconnected but I have a question. I'm doing this because I want to paint the engine bay so I want to remove as much as is reasonable. This harness has me confused though..... Does it disconnect from the firewall?
I'm talking about here-
I've started to kind of pick at it, but it's either really tight, or it just doesn't come apart. Before I break something..... does it disconnect here from the underdash harness?
Hi Stranger!,
There is a bolt in the middle of the fuse block which is screwed into the piece you seek to remove, unscrew it and pop the block off and then release the tabs at the firewall and you're golden.
Hope this helps.
That helps plenty! I shall continue the work..... later :D
But at least now I know what to do. Thanks a bunch!
Also... Super Moderator? oooh la la... lol. Things have changed a bit around here I see.
