Hi guys one more question about headlight vacum motor, I just bought a used motor supposed to be good no leaks I changed it, and it works fine while motor runs but wont hold vac when motor off, when changing it i noticed top hose had yellow stripe ,bottom green stripe . All manuals i've read shows the other way around i have no vacum out of the green hose only yellow one when car is running, what pos should bypass valve be at mine is at 3 and 9 o"clock. Chances are the motor might have leak anyway but the hose configuration has got me wondering thanks guys. I could use your wisdom.
