hi guys got a question is there a easy way to change headlight vac. cannister looks like i have to tear half the front apart i was hoping there was a trick to it . I've got a 70xr7 thanks
The rod that goes through the top of the vacuum motor should slide left and right to release the motor. If not it has probably welded itself together and you will have to disassemble the entire grill. This comes from practice. Just my 2 cents.:)
I was just hoping there was some magicial way of sliding it out/under by the front valance . guess i'll get out the tools Thanks.
I brought mine out from the top on my '70. Had to remove the driver's side horn-one bolt. I don't have an A/C condenser so this may allow more room.
