Randy Goodling sells longer bolts that will allow you to align the headlight doors. I bought a pair and they were a bear to put in. The photo in the previous reply shows the adjustment bolt that must be replaced. If you're real good, you can buy the bolt that will fit and is 1/4" longer than the current bolt, grind down the top 1/4" into an eight-sided configuration, and use that.
