Was all set to finally fire up the car after getting everything in place after adding a new cam and some Dart Eagle Iron heads. Solved the issue with mounting the accessories.
However, ran into a last issue that keeps me from starting the car. I can't get the spark plugs in. The passenger side bank has the header flange just in enough at 10 o/c that you cannot use a socket. The driver's bank is completely obscured as the plug holes are almost right under the tubes preventing view and any use of a socket. Clearly I am screwed big time at the moment.
Either I have to find headers that would work and it seems that Fox body headers are mentioned with these heads. Fox body headers work in a 1968 engine compartment? I also though of disconnecting the headers to access the plugs and then reconnect. I just don't know what kind of heat the driver's side plugs could handle being right under the tubes?
Or, since a 1/8" corner of header flange is the culprit is there some tool out there with a flexible extension that could be used to grind that corner out since no way the headers can come out?
