Any sure way to tell with out taking the heads off? This is about the only thing I could find from another forum.
The motor will run hot with the gaskets installed backwards due to restricted coolant flow.
But, you can tell if the gaskets are installed correctly without pulling the heads.There will be a small square corner of the head gasket sticking out just in front of the lower front head bolt if they are installed correctly.If installed wrong there won't be any little "tab" of the gasket sticking out.If you see the tab at the rear lower head bolt the gasket is installed wrong.All the small block Ford gaskets I have ever seen are like this.The rear lower bolt area has a radius on the gasket and the front has this square tab.Check out a gasket and you will see what I mean.
