I have a stock 302 with a street cam
It never starts easy until it warms up and then no problems.
Q: Would a hotter coil help? Engine 1000 miles rebuilt carb
adjusted to specs,everything new but the coil,and I tested
the coil's resistance primary/secondary ok.
I was thinking maybe a flamethrower coil would help.
It never starts the first time,takes several starts.
Looked in carb,seems to be getting a good stream of gas with
the link on the outer hole. Specs says outer,isn't this a leaner squirt?
Thanks
Super Moderator
Maybe your choke is not working?
Discussion Starter · #3 · (Edited)
302 w/automatic Transmission 2bbl I set the choke to 1 lean and fast idle 1400 rpm
choke plate 1/8" When I depress throttle slowly for fast idle cam then release it, then start,engine fires right up,idle fast and immediately dies.
I'm running 13" vacuum I guess because of the cam,I added a reserve tank for
vacuum brakes. I disconnected all lines and check the vacuum. My wife just filled the tank.
I rebuilt the carb and set the float level to specs.
I turn the air/fuel mixtures screws out another 3/4 turns
and adjust the choke to 1 rich but same thing starts and dies.
Like it's not getting enough fuel. Once it's warm at least a few days ago
it started and ran fine.
I also pulled all the plugs,they are fine.
I would think if it was a fuel pump,I would have trouble when it's warm too.
Discussion Starter · #4 ·
I have another carb, the throttle shaft is a little loose in the bore
it has a electric choke,would the choke help and is it 12volts direct?
I'm not crazy about building it, just maybe switching chokes or choke springs.
Ok, when it first starts, what happens if you DON'T expect idle to take over, but kind of FEATHER the throttle up and down a bit to keep gas flowing? I think it is a fuel issue, and would like to know if it does stay running when you FEATHER the throttle. IMO I don't think a coil would act like that.
Dale in Indy
Discussion Starter · #6 · (Edited)
Dale in Indy
I knocked a vacuum hose off the carburetor port .
I used a Exhaust Gas Analyzer and readjusted the mixture screws.
Starts idles fine now.
