Read Only
i have a 67 cougar with power drums, brakes work great when car in warm up.but when you start it up when it is cold the brake peddle is very hard and the car is hard to stop when it is cold but after it warms up the brakes work fine .. ANY BODY know what s may be causeing this ,THANKS CATMANDO :1zhelp:
:rolleyes: Almost sounds like your brakes could be frozen, as in iced up? Is it really cold where you are? It sur is here.
Read Only
NO ,JUST NORMAL COLD STARTS . THE PEDAL IS HARD TO PUSH DOWN UNTIL IT WARMS UP THEN THE PEDAL WORKS LIKE POWER DRUMS SHOULD ,
:( Does your 67 have standard or power brakes?
OK, sorry Catmando, you did say power brakes.
:eek: To me it sounds like you are not geting the power
to the system. The brake booster is vacuum suspended and uses manifold vaccuum for its power. The only adjustment is the push-rod, so why the brakes dont work when cold I am not sure.
If you think the booster is working try the following conditions,
brake pedel linkage sticking, collapsed or leaking vacuum hose,leaking vaccuum chamber, or a leaking automatic transmission throttle vavle vaccuum line connection or fitting. If none of those prove to be the trouble maybe the power unit should be replaced.:cry:
