I have did a search but mostly adds came back . Maybe I am not used to it will play later .
Any how I am trying to remove the rt assy . I have every bolt out and am trying to slide the female end off the double D bar . It doe's look like its crimped some , I used some heat but no movement . I carefully used a dead blow against the rag joint , but it won't come off .
It will how ever slide back and forth on the double D bar about a 1/2 inch or so . I am missing something here , when I studied the parts I see they can be separated .
