Call, text or email me at 815-669-zero-eight-five-two. Please, no texts or calls after 10:00 PM. All prices are negotiable.
I have the following Ford / Mercury / Lincoln (FoMoCo) Mustang, Cougar, Comet or Falcon parts for sale:
-Ford Nine Inch Rear End (9 in rearend) housing with Disc Brakes. It has "Torino" ends (big bearing). 28 spline axles with 5 x 5 lug pattern. $200
-Two Ford 9 inch center carriers (pumpkins) with:
** WAR Case, 0E27 date code, 3.89 gears, Ford 9" $150
**C4AW case, 5K22 date code 3.50 gear ratio, nine inch $175
-65-66 Mustang Right & Left reproduction fenders in good condition. $50 each
-1965-1966 NEW Mustang Monte Carlo Bar (chrome & straight) $30
-1965-1970 Mustang Export Brace Chrome $30 (fits 64.5, 65, 66, 1967 / 67, 1968 / 68, 1969 / 69, 1970 / 70 Mustang and probably Cougar, Falcon, Comet, etc)
-289/302/351w timing chain cover for mechanical fuel pump $25
-1969 351W heads (some mild pocket porting done with exhaust bumps removed, hardened valve seats, undercut Manley valves, Crower springs, screw in rocker studs & guide plates). One is C9OE-G casting '69 and the other is D0OE-C '70 (DOOE) casting with 60.4 cc combustion chambers, 1.84/1.54 valves. These are the best factory Windsor heads available and can bolt onto a 260, 289, 302, 5.8 L or 5.0 L motor. $550
-Harland-Sharp 1.7 roller rockers and polylock rocker arm nuts that were on these heads. $200
-Two 1999-2004 Bullitt / Mach 1 rims 17x8 inch wheels (aka bullit, bullet, bulet, bulit, bulett, bulitt, bullett). Stock anthracite color. $75 each
-65-66 Mustang 289 V8 5-lug Spindles, Complete, drums, etc. $175
-Five vintage Torque Thrust D wheels 14 inch with tires. $425
SATAN! Get behind me! Is that a straight or curvedexport brace? I need the 3.89 gears, too. and the wheels, and....
Im interested in the 9in rear along with 3.50 gears. Let me know if they are still available and how much shipping would be to zip 11795.
Thanks Ryan
I see an 815 area code, where are the parts?
I feel your pain Brian! LOL
These are on the rockford, Il craigslist I just thought there was plenty of good pickens in there.....
