Allright all you Guru's.....I swapped from manual drums all around to an SSBC Power Disc front, and fastmercs Crown Vic discs in back.....question....the SSBC kit says nothing about changing the brake light switch to a power version...searched around here, but found nothing definitive about conversion requirements. Thoughts?
Thanks!
I have never done the swap, since I have always had factory power brakes. But, I did get the manual version of the swtch from the parts store by accident once and didn't know it. I had no idea that my brake lights didn't come on unless I was braking hard. If I just stopped slowly they never came on, so it may be neccesary. Have someone watch the lights as you push on the pedal and find out at what point the lights come on. It should be almost as soon as you touch the pedal.
Absolutely need the PB switch for the reason Mike cited.
