This nearly Complete Granada disc brake set up - The ONLY item missing is the Adjustable Brake Prop Valve. The spindles are complete and have the shims to adapt to the earlier tie-rods - this set up came off my 65 mustang (65 tie-rods are included if you want them). Dual Master cylinder included with the small brake lines to the adj. prop valve as well. The rotor hubs were turned to fit the early styled steel wheels too.
The clear plastic bag contains the Dual Master cylinder, the white bag contains the tie-rods.
Complete bolt on kit as is and less than a 1000 miles on them. I switched to a bigger brake kit.
asking 500 or make an offer - located in the SF bay area - email me @ [email protected]
